| You don't have to be at TDC, any place will work. For your case, I would take the covers off (requires removing the rad, fan, water pipes) and use a pry bar to hold the tensioner where it is, loosen the two bolts and nut holding it on, let it relax slightly and retighten everything. Then use a wrench (or the starter) to turn the engine a turn or more (and backwards if you have a wrench) and check the actuator length (easy once you see it)
------------------------------------------------------------------ 1992 300ZX NA 5 Sp (Dead) 1990 300ZX NA Auto 2+2 (Dead) 1990 300ZX TT 5 Sp (Building) 2004 G35 Sport 6MT (DD) |
